tv box t96 mars como desbloquear ?
    Eu tenho uma TV BOX T96 MARS RK3229 a placa tem o numero XT-MX1VB-V10 que se encontra bloqueada não é reconhecida pelo pc e não sai da luz vermelha não consigo encontrar firmware mas tambem não sei em que pinos fazer curto para a desbloquear agradeço se alguem tem conhecimento desta placa me ajude
    I have a TV BOX T96 MARS RK3229 the card has the number XT-MX1VB-V10 that is locked is not recognized by the pc and does not leave the red light I can not find firmware but also do not know in which pins do short to unlock thank you if someone is aware of this board help me
    2 Photos
    Na continuidade deste tópico sei da possibilidade de recuperação desta placa mas estou com dificuldade em descobrir em que pinos fazer o (curto) para que o pc reconheça a placa se por acaso alguem poder ajudar agradeço .
      Hi ,
      please use ENGLISH , otherwise we can not help .
      Try Pins 7/8 or 8/9 , u have to start telling from the small triangle , that u can see .
      greetings / gefattern
        Ok obrigado não sei falar nem escrever inglês mas vou tentar traduzir quanto ás suas instruções eu depois dou noticias
        Okay, thank you, I do not know how to speak or write English, but I'll try to translate your instructions and I'll give you some news later.
          Hi ,
          your English is good enough to understand , u understand and write it better then much others here .
          good luck / gefattern
            Thank you friend but in reality I do not write English I only use the translator / box I thank the help because I already managed to give life to the usb ports but I could not get it recognized by the pc but I will keep trying. Regards ... Nelson
              As promised I just say that I could not unlock the box t96 mars rk3229 by the short method on the pins turns the red light but is not recognized by the pc I think it will have another problem. greetings
                Hi ,
                so you can connect your Box to Pc in MaskRomMode if it turns red it is connected ,
                did you install the Drivers ???
                what Windows do u use ??
                please use YouTube for more Info about flashing a Rockchip Box , there u can see
                what steps are made to get it working ,
                good luck
                  Anyone have the firmware for RK322x MX1VB_V10 chip?
                  Is a SCISHION V88 MARS
                  tHANKS
