Flash new kernel for K-R42 with finless ROM_Flash_Tool_137
I was wondering what the procedure is for flashing wasser kernels with ROM_Flash_Tool_137. I see the options on top for flash, nfs and ram and a hex offset. I want to flash a wasser kernel and I hope someone can direct me to the correct way with finless tools. Thanks in advance.Tags: None
Originally posted by Gfunk View PostI was wondering what the procedure is for flashing wasser kernels with ROM_Flash_Tool_137. I see the options on top for flash, nfs and ram and a hex offset. I want to flash a wasser kernel and I hope someone can direct me to the correct way with finless tools. Thanks in advance.
- Untick all items except 'kernel'
- Click the empty box on the kernel line (column '...')
- Navigate to the location of the kernel image and select the file
- Click 'Run'
Re: Flash new kernel for K-R42 with finless ROM_Flash_Tool_137
Originally posted by luinx View Posthi
Do i need boot.img for to Flash kernel
What Rom are you using?
There are currently 2634 users online. 0 members and 2634 guests.
