VORKE V2 Pro Intel Kaby Lake R i5-8250U 8GB DDR4 RAM 128GB SSD Mini PC AC WIFI Gigabit LAN HDMI USB 3.0 TYPE-C
    Intel 8th Gen Core i5-8250U
    The Intel 8th Gen Core i5-8250U, developed under the codename Kaby Lake R, is an embedded Quad-core processor, results in a higher multi-tasking potential when compared to processors with more cores.
    This Core i5 series CPU operates at a stock clock speed of 1.60 GHz, the Core i5-8250U has been tested to handle a maximum overclocked speed up to 3.4 GHz. Its cache size is 6 MB SmartCache,
    Operating System of Your Choice
    Moreover, you can also use the OS of your choice, from Linux distributions to Windows 10, Chrome OS, whatever does the job, besides the preinstalled Ubuntu16.04.
    DDR4 8GB RAM, 128GB NVME SSD,
    It boasts DDR4 8GB RAM, 128GB NVME SSD, advantageous in performance, security and reliability.
    IEEE 802.11ac
    IEEE 802.11ac, one of the wireless networking standards in 802.11 family, is developed in the IEEE Standards Association process for the purpose of high-throughput wireless local area networks (WLANs) on the 5 GHz band.
    Gigabit LAN
    Gigabit LAN provides a data rate of 1 billion bits per second.
    Other Features
    Ultra compact PC design at only 0.6L (39 x 124 x 129mm)
    Supports 2.5" HDD/SSD, 7.0/9.5 mm thick (1 x 6 Gbps SATA 3)
    VESA mounting Bracket (75 x 75mm + 100 x 100mm)
    Applications
    Office Work: Office, skype, yahoo, outlook and all other office requirement support and runs perfectly.
    Design Work: Photoshop, CoreIDRAW, Dreamweaver, IIIustrator, Flash, Indesign and others.
    Game Playing: Support most of the online games and PC games, like Warcraft, Counter-Strike (CS), support 3D games.
    Entertainment: Support 4k video play, XBMC and others.
    Specification
    General Brand:VORKE
    Model:V2 Pro
    Hardware OS: Ubuntu16.04 pre-installed; Supports WIN8.1 64bit;WIN10 64bit
    CPU: intel 8th Gen Core i5-8250U 1.60GHz / 3.50GHz
    GPU: Intel® UHD Graphics 620
    RAM: 8GB DDR4 2400Mhz
    ROM: 28GB M.2 NVME SSD
    Communication WIFI: IEEE 802.11ac ,Intel-3165, Dual Band Wi-Fi
    Bluetooth: 4.2
    LAN: Realtek RTL8111F; 10/100/1000Mbps
    Media Onboard Audio: Realtek ALC269-VC3
    Interface 2 x USB 3.0
    2 x USB2.0
    1x Type-C
    1 x Head phone & Mic Jack
    1 x HDMI ™(1.4b)
    1 x RJ45
    1 x DC-In
    1 x Kensington lock slot
    VESA: Bracket included and screws included, Supports 75 x 75 and 100 x 100 mm
    Expansion Slots:
    1 x M.2 NVME SSD 2280 slot (Optional 128GB/256GB of flash storage)
    1 x M.2 PCIe 2230 Key-E slot occupied by the Wi-Fi+BT card
    1 x 2.5 in SATA 6.0Gb/s (7.0 / 9.5 mm thick)
    Power Input: AC 100-240V
    Output: DC 19V 2.1A
    Dimension&Weight 1.52 inches (39 mm) *5.03 inches (129mm)*4.84 inches (124 mm)
    Package Contents 1* V2 Pro Mini PC
    1* VESA Bracket
    1* Power adapter(A right power adapter will be sent according to your shipping country)
    1* User manual
    Link: https://bit.ly/2JiBeXV
    if you want to know more details,check our blog!
