We have the New Vorke V2 Pro Intel Kaby lake, with a multitude of flavours and Options with Ram and SSD etc
Specification
General | Brand:VORKE Model:V2 Pro |
Hardware Flavours | OS: Ubuntu16.04 pre-installed; Supports WIN8.1 64bit;WIN10 64bit CPU: intel 8th Gen Core i7-8550U 1.80GHz / 4.00GHz GPU: Intel® UHD Graphics 620 ROA: 8GB DDR4 2400Mhz ROM: 256G M.2 NVME SSD OS: Ubuntu 16.04 pre-installed; Supports WIN8.1 64bit;WIN10 64bit CPU: intel 8th Gen Core i5-8250U 1.60GHz / 3.50GHz GPU: Intel® UHD Graphics 620 RAM: 8GB DDR4 2400Mhz ROM:128GB M.2 NVME SSD |
Communication | WIFI: IEEE 802.11ac ,Intel-3165, Dual Band Wi-Fi Bluetooth: 4.2 LAN: Realtek RTL8111F; 10/100/1000Mbps |
Media | Onboard Audio: Realtek ALC269-VC3 |
Interface | 2 x USB 3.0 2 x USB2.0 1x Type-C 1 x Head phone & Mic Jack 1 x HDMI ™(1.4b) 1 x RJ45 1 x DC-In 1 x Kensington lock slot VESA: Bracket included and screws included. Supports 75 x 75 and 100 x 100 mm Expansion Slots: 1 x M.2 NVME SSD 2280 slot (Optional 128GB/256GB of flash storage) 1 x M.2 PCIe 2230 Key-E slot occupied by the Wi-Fi+BT card 1 x 2.5 in SATA 6.0Gb/s (7.0 / 9.5 mm thick) |
Power | Input: AC 100-240V Output: DC 19V 2.1A |
Dimension&Weight | 1.52 inches (39 mm) *5.03 inches (129mm)*4.84 inches (124 mm) |
Package Contents | 1* V2 Pro Mini PC 1* VESA Bracket 1* Power adapter(A right power adapter will be sent according to your shipping country) 1* User manual |
