If anyone could help please that would be awesome.
Need Firmware for M9C Pro 4K
I recently got given this box and like most boxes i bought with the Amlogic S905X and android 6.0 has the dark picture issue im trying to locate a new firmware update but cant find anything or much information on this TV box.
If anyone could help please that would be awesome.Tags: None
I found a solution the Wechip X96 seems to be the same box or mine is a clone, i flashed the firmware using USB burning tool and everything seems to work better and faster, i am also not suffer from the dark picture issue anymore.
here is the link for the firmware below - USE AT YOUR OWN RISK
https://onedrive.live.com/?authkey=%21AG4iCJUWC1VlW7g&id=46126D253EA3A2B2%21211&cid=46126D253EA3A2B2Store photos and docs online. Access them from any PC, Mac or phone. Create and work together on Word, Excel or PowerPoint documents.
M9C PRO ORIGINAL FIRMWARE DOWNLOAD!! :
https://drive.google.com/drive/folde...h9?usp=sharing
AND I RECOMMEND TO DOWNLOAD THE FOLDER JUST USE http://jdownloader.org/jdownloader2 to download it all at once. and use twrp to restore the backup, it took forever to get the file , had to upload it too, from my m9c pro 4k, andthere u ago
Originally posted by NetherKingdom2 View PostM9C PRO ORIGINAL FIRMWARE DOWNLOAD!! :
VERY IMPORTANT @eggyfresh and after u get the m9c pro firmware installed, just go to settings and do a factory reset , not in twrp but in the settings app, so my old apps arent there and you have space because it only had around 579 mb i think , when i back up the image, sorrry, once u reset it should be fine
There are currently 4876 users online. 0 members and 4876 guests.
