W95 only 720P !!!
    W95 only 720P !!!
    Why W95 has only 720P HDMI output? HDMI settings are 1080P60 but test video is always 720P. On same TV i have full 1080P with another box s905W 2/16GB.
    Please, fix that bug.
    W95
    Another box
    Test file: https://www12.zippyshare.com/v/lROKEH3v/file.html
    same here plz is there another rom or something to fix it ,
      W95 is a budget Amlogic S905W device.
      It only has a 720p frame-buffer.
      If using Kodi, SPMC and the manufacturer integrated frame-rate switching then the videos will play at 1080p or 4K.
      If not then everything will be downscaled to 720p.
      S905X devices support 1080p.
        Use Coreelec to unlock 1080p output + frame rate on Kodi.
