Exhibition Information
Beelink is now showcasing two upcoming Intel Gemini Lake based mini PC at the Hong Kong Electronics Fair 2018.
Beelink Gmini1 is a compact actively cooled mini PC powered by Intel Celeron J4105 processor with dual HDMI output, and a 2.5″ SATA bay, while Beelink S2 is a larger – yet thinner – fanless model based on Celeron N4100 processor, also equipped with SATA bay, but instead featuring HDMI and VGA video output ports. Beelink Gmini1
Specifications:- SoC – Intel Celeron J4105 quad core processor up to 2.5 GHz with Intel UHD Graphics 600; 10W TDP
- System Memory – 4GB DDR4
- Storage – 32GB eMMC flash, 2.5″ SATA bay, micro SD card slot
- Video Output – 2x HDMI ports
- Audio – Via HDMI ports, built-in microphone, 3.5mm audio jack
- Connectivity – Gigabit Ethernet, dual band 802.11a/b/g/n/ac WiFi, Bluetooth 4.0
- USB – 4x USB 3.0 ports
- Misc – Power button
- Power Supply – 12V/3A DC
Beelink S2
Specifications:
Click to Enlarge
- SoC – Intel Celeron N4100 quad core processor up to 2.4 GHz with Intel UHD Graphics 600; 6W TDP
- Storage – 32 or 64GB eMMC flash, 2.5″ SATA bay, M.2 SSD slot, micro SD card
- Video Output – 1x HDMI, 1x VGA
- Audio – Via HDMI, built-in microphone, 3.5mm audio jack
- USB – 2x USB 3.0 ports, 2x USB 2.0 ports, 1x USB type C port
- Misc – Power button and LED
Two screws hole for VESA mount are also present on each side of the cover for the hard drive.
Both mini PCs will run Windows 10, and support Cortana with their built-in microphone.
Beelink S2 is basically ready, since they’ll start mass production in mid April, and Beelink Gmini1 is scheduled for the beginning of May. The company told me over Skype that pricing is yet to be confirmed.
Notebook Italia also uploaded a YouTube video about the new Beelink mini PCs introduced in Hong Kong.
Source CNX
Intel Kaby Lake G with AMD Radeon RX Vega graphics. Photos and live video.
In addition to the first models with Intel Gemini Lake processors ( GMini1 and S2 ), Beelink has renewed the rest of its offer by introducing new versions of Mini PCs already on the market, enhanced in hardware or in the interface kit. Let's talk specifically about the Beelink AP34 Pro and Beelink KT03 based on Intel Apollo Lake processors and a new Beelink KB-G1 Gameequipped with Intel Kaby Lake-G CPU and intended for gamers.
]https://youtu.be/wpSvto01oQg
It is clear that the Chinese company intends to cover all market segments and to propose a solution that is valid for each type of user. We did not have the opportunity to thoroughly analyze these three Mini PCs but, thanks to the video presentation shot at Global Sources Electronics Fair 2018 , you can get an idea about the design and specifications offered by each product.
Although aesthetically identical to the AP34 already on the market that will replace, the new Beelink AP34 Pro is differentiated by the addition of some interfaces. Still based on an Intel Celeron N3450 quad-core processor (Apollo Lake) that will support 4K video, with 4 / 6GB of DDR3 RAM and 64GB of eMMC 5.1 memory further expandable with a microSD card slot, the latter model will feature four USB 3.0 ports (before they were 3) and two HDMI 2.0 (before only a 1.4), as well as an audio jack, RJ-45 Gigabit Ethernet port, 802.11ac dual-band WiFi with a showy adjustable antenna and Bluetooth 4.0.
Beelink KT03 instead seems a new model, the first of a new family dedicated to industrial applications and for this configurable according to business needs: has a quad-core Intel Celeron J3455 (Apollo Lake) 1.5GHz, flanked by RAM SoDIMM DDR3L (up to 8GB maximum) and storage consisting of one SATA slot and one mSATA with the possibility of expansion through an SD card slot. The fleet will be no less with four USB 3.0, two HDMI 2.0, two RJ-45 Gigabit Ethernet, two COM ports and microphone connector and speaker. All fanless.
The last and perhaps the most interesting of the group is Beelink KB-G1 Game Mini PC , a model much larger than what we have seen so far because it hides a high-end desktop PC hardware inside. KB-G1 integrates Intel Core i5 / i7 processors (Kaby Lake-G) and specifically the sample on display is equipped with a 3.10GHz Core i7-8809G with AMD Radeon RX Vega M GH graphics, 2GB of DDR4 RAM ( expandable up to 32GB) and two SATA hard drives in various sizes. Reduced the presence of a fan inside to dissipate the heat produced by these components. On board we also find five USB 3.0 , two HDMI 2.0 , two DisplayPort, 3.5mm audio jack, RJ-45 Gigabit Ethernet
Beelink AP34 Pro, Beelink KT03 and Beelink KB-G1 Game, although different, are all based on Windows 10 with support for the Cortana virtual assistant that will allow you to control them even remotely, using voice commands. It should not miss much for the launch of the trade, indeed Beelink KB-G1 Game is currently in mass production.
Source:notebookitalia
There are currently 2923 users online. 1 members and 2922 guests.
