H96 Max problems
    H96 Max problems
    hello, I bought this box(https://www.wish.com/product/5a6f1fa895ebed6bbea93e1c) , unfortunately can Unable to change the default launcher!
    see Attachment.
    Does anyone know if I can change the three applications? "Netflix- youtube- google play"
    I have another one too Launcher but tried, but I have not found a reasonable one! the only one I can not test is Nova Launcher is faulty!
    which box around the 70€ is better than the one I bought? (from the wish shop)
    I have the same box, H96 max...and from what i have read about those applications is you cant change them.I wanted to make one of mine Kodi, but was told they are permanent.If you hear anything about that please post....
      Hi both ,
      only a Pro & Dev. can make changes like that , the Launcher / System must be modified
      for that , why not simply installing a new Launcher , good luck
      greetings / gefattern
        "only a Pro & Dev." do you mean that H96 Pro Plus "https://www.wish.com/search/H96%20pro#cid=5a9e81acdc0c28746bf6a52e"
        there is no qualified Launcher!
        or do you mean Professional Development "Pro & Dev."
          which box would you recommend?
