What to buy? Which one works...I mean really works.
I have been using the MeCool MS8 Pro and have been very happy with it, but the tinkering bug has bitten and I want to explore (play with) a Rockchip based box with the RK3399. Which one really works as good or even better than the MS8 Pro. I need it to work with Netflix and Amazon Prime Video preferably in 4K but would settle for 1080p.Tags: None
Originally posted by rahjer View PostI have been using the MeCool MS8 Pro and have been very happy with it, but the tinkering bug has bitten and I want to explore (play with) a Rockchip based box with the RK3399. Which one really works as good or even better than the MS8 Pro. I need it to work with Netflix and Amazon Prime Video preferably in 4K but would settle for 1080p.
for Gaming / Internet , i think a good Box , but until now , as long RK3399 not supports Widevine L1 ,
for your needs not really the right Box . What about the newer Realtek 12... ??? Boxes , someone here
wrote that they are much better in this things , but i am not the Pro in that , for sure you need a Box
with L1 support . With a little bit more Luck , i had the chance to by a NvidiaSchield from the Bay , but
not enough Luck , good Devices too , for your needs (and all other) .
hope it helps / greetings / gefattern
There are currently 3136 users online. 3 members and 3133 guests.
