x96mini / A95x install Magisk / get rid off "chinese root" using terminal
    Dear guys, I already asked on how to install magisk on devices which are "pre-rooted" but when you install SU and update you will stuck in bootloop.
    A user answered my question and described on how he installed magisk and uninstalled China stuff.
    Unfortunately I cannot find that thread anymore.
    Can anyone kindly help ?
    found... https://forum.xda-developers.com/sho...&postcount=104
      1. Install Magisk Manager and Magisk
      2. Deleted any su
      Sbin​​​Sbin/su
      System/bin/su
      System/sbin/su
      How continue?uninstal Magisk?
      How I get normal Root then?
        I just fired up my x96 mini, opened magisk and set TELEKOMSPORTS to hide.
        App runs!!!
        So is it a MUST to delete all su files??
        Or just highlight desired app under MAGISK hide?
        Then I wpould like to have back su's :-P
          Flashed unroot script from XDA
          Successfully flashed UPDATE-SuperSU-v2.82-20170528234214.zip using TWRP VITmod. No bootloop!
            Still Root....flashed Tanix Mini fw, then unSu_signed and now No More Root.......!
              Hi, could you help me? What SU files do I have to delete? I just found SU on xbin. I installed Magisk, but it says it is not installed.
