Here is instructions to let the device go to firmware upgrading mode:
*** (It should be applied for all A10 devices)***
- 1. power off the device
- 2. Press and hold any physical key except the power key on the device(ie, press and hold Vol+ key, still holding in 3 and 4)
- 3. Press and hold power key for about 2s(power on the device, when powering on, if a key is pressed, the devices will not boot until key released or 4)
- 4. Release power key and press power key 3 times(i usually just keep pressing the power key)
Typically you need to pull the battery to back out or exit the bootloader without doing anything.
Can/has/will someone who has opened the case on the pmid701c try this procedure? Check first if you can unplug the battery!!!
*** If you have never done this please don't just becuase I am asking! ***
It looks like making a perma-brick out of this SOC/mobo is unlikely but the recovery procedure could be far from trivial.
