TX3 Pro 1GB/8GB roms
hello all' i have a tx3 pro 1gb/8gb version with a p212 board' im after a decent custom rom for it' the stock rom is dredful to say the least lol or would i be able to say dual boot a open/libreelec version on the box because i dont really want to lose the android side many thanks.Tags: None
i (believe) i have stock rom for the Nanya type (serial includes NY)
http://www.mediafire.com/file/a37fet...70105.img/file
SD/TF Card http://www.mediafire.com/file/2umg4q...nyddr.zip/file
this is older but not the oldest
http://www.mediafire.com/file/qnqi6n...61222.img/file
this one almost worked for me but i believe i have hardware problem..
i reflowed chips and green scrambled 1 second screen during reboot android updating screen stopped, so i guess its working better but stuck with flashing not taking any roms so far.
i think i have to short the pins as its not completing with any roms at %7 0x30201004
Edit: after very good reflow im able to flash most roms with force erase all with usb tool 2.1.2 from amlogic toolkit .. i had a loose nand or ram chip.
ohh finally found some hope..
https://forum.xda-developers.com/android/help/how-to-fix-wifi-driver-tx3-pro-tv-box-t3876108Last edited by LatinmcG; 21 January 2020, 05:51.
There are currently 2007 users online. 1 members and 2006 guests.
