MECOOL KII PRO TV Box recording timer issue
    Hi guys,
    I've bought a KII PRO TV Box with DVBT2+DVBS2 tuners
    (it's very similar to model KI PRO as of the thread linked below )
    I'm very satisfied of the unit, even using the stock firmware but there's something which always fails to operate properly: the timer of the DTV app.
    The "PowerOn" event never works (I've configured the options so that the unit goes to sleep upon pushing the power button) but even leaving the box turned on with the DTV app running in background (do open it, add events to the "timer list" then return to the main screen pushing the home button of the remote control) the recording events never take place.
    Is anybody using the timer function and has anybody faced (and solved, if the issue was the same hereby described) this problem ?
    Thanks in advance.
    Click image for larger version Name: 20170508173858_76181.jpg Views: 1 Size: 89.1 KB ID: 646052 Click image for larger version Name: 1494295147752201.jpg
