New mk809 iii user
    New mk809 iii user
    i've bought mk809 iii android tv box and i have a problem with wifi... it can't connect to my router that is only 2 meters far from tv...
    i've seen somes of you had the same problem and i downloaded NEOTV HYBRID CROM 20130724 MK802IV PODOOR T518 firmware to fix the wifi problem
    i launched RKAndroidTool and when i click on run i can't apply firmware...
    do you have solution for my wifi detection?
    thank you
    Originally posted by t3k1lla View Post
    thank you
    neomode maked new Rom v 1.3,you should use this one,it's better.but I think it could not solve the wifi problem .WiFi signal is not good because of the bad antenna
      that's sad... so no way to use wifi?
        I've had terrible WiFi problems, to the point of not working at all, flashing neo's rom and sam's kernel have fixed it completely.
        Also making a hole in the case and taking the antenna out also makes a HUGE difference.
          can you explain me how to flash rom?
          i can't find any tutorial
          thank you
          (i'll try making hole and taking antenna out)
            thank you
            This is the thread that fixed my problems:
            This is the rom flashing instructions:
            before selecting a rom\kernel you should find out what device you have (wifi chip etc...).
            this is the antenna mod i have done, and it made a huge difference. (can also see the my heatsink mod=D)
              i'll check this as soon as possible thanks
                hi,
                i put the antenna out of the box and it works now perfectly... no need to flash rom... juste a little bit disappointed by mu purchase
                i've ordered wireless keyboard and i'm looking for good apps to use with it
                  hi,
                  glad it helped
                    i've ordered rc-12 keyboard i hope this one will work well with android box...
                    i'm looking for good multimedia server (like ps3 media server for android) with nice interface
                      i use the measy rc12 as well, it's working.
                        perfect
                          hi,
                          i've received my rc12 that works fine! can you just tell me how it is possible to use "back" function as android has?
                          i can't find the right button on keyboard if you know what i mean
                          thanks
                            hi,
                            thanks
                            its on the left side below the arrow keys.
                            in xbmc you can also use ESC or BACKSPACE for back.
                            *in android use the right mouse button
