Pepper Jobs W10 GYRO 2.4G 6-Axis Air Mouse Keyboard Combo with Backlight for Windows 10
    W10 GYRO redefines the way that you control your Win10 based HTPC.
    W10 GYRO is the world's 1st and only 6-axis gyro air mouse designed specifically for the Windows 10 system.
    All shortcut buttons and hotkeys are fully optimized for Windows 10. Utilizing 2.4GHz wireless technology with an USB receiver, W10 GYRO can be operated without any need for manual driver installation. Simply plug in the bundled USB receiver to your Windows 10 based PC, and you are all set and ready to enjoy the amazing control experience from your sofa.
    W10 GYRO is equipped with backlit LED which means you don't have to worry about not seeing the keys while using in the dark.
    Plug and play, operating distance up to 10 meters.The operating distance of W10 GYRO is up to 10 meters from your computer.
    Low operating power, operated by 2 AAA batteries (not included).
    Full QWERTY keyboard for your ease of inputs.
    IR learning: this remote can learn up to 34 keys from your TV IR remote.
    In addition, W10 GYRO comes with the TV remote learning features on the front side, you may let this smart remote learn up to 34 keys from your TV IR remote! Specification
    General Battery Requirements: 2 x AAA batteries (not included)
    Operating Range: 10M
    Target OS Support: Microsoft Windows 10
    Operating Mode: Win 10 mode (2.4G Wireless keyboard & mouse) / TV mode (IR learning remote control)
    Working Current: ≤30mA
    Standby Current: ≤30uA
    Certifications: CE, FCC, RoHS
    Dimension & Weight Product Weight: 100g
    Package Contents 1x W10 GYRO Wireless Remote Control
    1x User manual
    Buy now:https://goo.gl/26SyNZ
    Coupon:PFDHAHHS
