New Firmware for the mk90211 Found this and seems to run very fast and works lolipop (ugoos parts think few parts lol)
You may only view thumbnails in this gallery. This gallery has 14 photos.14 PhotosMany devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Tags: None
Working
voice on cell apk.
network
bluetooth
wifi
sd card
USB
so far seems smooth and you tube st 1080p.
downloaded rom and it did an update after loading took at bit to get downloaded (time wise ) but all in seems like best rom so far for the mk902ii.
give it a whirl if your board with rkm firmware.
Hi Scooter ,
i saw that you had Problems with your RK3288 Device , my UT3 is bricked too & i am really do not know how to
unbrick it , it always ends in Errors like that : download boot fails , prepare IDB fails & download IDB fails , i tried
different Roms , Tools , Windows Version , if i make a Test with AT the Output of the IDB says 0-4 , but it only give
out from Sector 0-3 , so the latest Sector is missing , i think the "uboot" or Bootloader" or similar is corrupted , do
you know any Solution for this kind of Problem , later i can upload some Logs for better understanding .
Did you ever heard about a Tool call "GPG Android Tool" not sure , but i think it is a DeveloperTool for Allwinner & RK
Devices , shall it be possible to restore with a Tool like that , i can upload later , maybe it is a useful Tool ???
greetings / gefattern
Never see tool. Maybe good?
I had to put device in mask mode but wouldn't take firmware. Ended up finally flashing with the original stock firmware that shipped with device that one worked. But man not damaged on mine.
Some times I put off to side then pull back out when bored or waiting for new box to play with. Flash different firmware just to see if comes back to life. Kinda like frankinstine monster keep trying different things until it breaths life again lol.
try flash this one what you got to lose not like it's going to brick itMany devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
thanks for answer , later i will upload some Logs that i made the last times of trying ,
on my UT3 i dont need to short the "Nand" directly , i have two golden plates in front
of the Nand , like seen in the "short Pins Mask ROM MODE" Thread here on FT , but
maybe this is the wrong think , but what shall be the difference in MRM if i do it direct
on the Nand , i always use the Power while flashing , try and come back later , i report
the Logs and results of flashing in the Thread i made Weeks ago .
UT3 bricked IDB bricked ??? the Name of theThread
PS : do you know this Tool GPG Android Tool ??? is it helpful ???
Originally posted by neomode View PostWhen you do this short on the Nand Chip it erase it in some manner that you can reflash it.
What you tell is that the Boot Loader on the Nand Chip is corrupt and need erased.
I know that failure from my Ugoos RK3288.
Neomode
thanks for answer , hope you are right ,press thumbs , report the results .
Good let us know how it works on that device seems fine on the mk902ii it have no issues play video. Runs fine everything working multi window work to.just try to save update but it disappear soon as update no option to save after download. You tube 1080 p netflick not checked yet I try later.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
hellllllllllp
first thanks a lot for the ROM i have rikomagic v5 and followed all the steps above but after successful ROM restore v5 didn't boot and no signal on TV and also couldn't get it to recovery again to write another ROM where my PC didn't detect v5
is there any way to make it work again with soft ware i have tried this tutorial http://chinagadgetsreviews.blogspot....gic-v5-tv.html
but v5 dint boot either
and what about shorting pins which pins
thanks a lot for all the info we got and always get from you
There are currently 1703 users online. 1 members and 1702 guests.
