This week, OUKITEL released the second tri-proof smartphone OUKITEL WP5000. WP5000 is one of the first rugged smartphones with latest popular 18:9 aspect ratio display and high performance. Except the strengthened body which combines Polystyrene Ebonite and Polyethylene Flexible Glue to ensure waterproof and shock-proof, WP5000 also gets a tempered Corning Gorilla Glass screen, protect it from daily life scratches staunchly. What’s more, WP5000 is IP68 waterproof and 6 grade(highest) dust-proof certified, it can survive from 1.5 meters water soak for half an hour. To demonstrate its reliability, OUKITEL conducted many extremely torture tests. OUKITEL also announces that until April 24th, WP5000 presale flash sale are hot ongoing on Banggood store at a discounted price.
Though tri-proof smartphones are said to be designed for those who often go outdoors, WP5000 is quite a good choice to use daily as we may come across many situations that damage our mobile phone. OUKITEL shows some examples of daily life accidents that WP5000 may encounter. Beyond any doubt, WP5000 will not be scratched even a little bit with its corning gorilla glass.
Main specs of OUKITEL WP5000:
· 18:9 aspect ratio 5.7-inch IPS-display with a resolution of 1440x720 pixels, covered with Corning Gorilla Glass 3;
· MediaTek Helio P25 octa-core processor,2.5GHz ;
· GPU: Mali-T880 MP2 900MHZ;
· 6 GB RAM, 64GB ROM;
· 128 GB expandable memory; support microSD cards;
· Dual-lens rear camera with sensors at 16 and 5 MP, main sensor interpolated to 21MP;
· 8-megapixel front camera, interpolated to 13MP;
· Support two nano SIM card or 1 nano SIM with 1 SD card; support 4G LTE;
· 5200mAh battery with 9V/2A fast charging;
· Android 7.1.1 Nougat;
· IP68 waterproof, 6 grade dust-proof, shock-proof.
· Fingerprintsensor /Proximity sensor/Gravity sensor/Light sensor/Compass/gyroscope/Notification LED
Now on the banggood store, the WP5000 is still during presale flash sale promotion, during which you can save $30 from retail price. To know more about it, click here: http://www.oukitel.com/products/wp/wp5000-87.html
