I just realised this is the problem with the MTK T9 tablet, that's why I had to increase the internal storage for apps, which makes this post redundant.
Move apps to external SD card.
I increased the T9's internal storage ability to 8gb a few years ago, but the memory is almost full of apps and my external 32gb micro SD card has loads of space. I tried to free up internal storage by moving apps to USB, but this only appears to have moved it to another part of the same internal drive. Although the external SD card is in the list, there is no option to move apps to it or load and run apps from the SD card. Is there a way to do this.
I just realised this is the problem with the MTK T9 tablet, that's why I had to increase the internal storage for apps, which makes this post redundant.Last edited by Pennyless; 22 April 2018, 10:18. -
Originally posted by Pennyless View PostI increased the T9's internal storage ability to 8gb a few years ago, but the memory is almost full of apps and my external 32gb micro SD card has loads of space. I tried to free up internal storage by moving apps to USB, but this only appears to have moved it to another part of the same internal drive. Although the external SD card is in the list, there is no option to move apps to it or load and run apps from the SD card. Is there a way to do this.
if you have "root" u can change the "mountPoints" , so you can make a 32/64GB SDCard to internal Storage ,
with the big Brother "G" you can find Infos about that , good luck (Backup your Data & Apps before)
greetings / gefattern
Originally posted by mitchell4you View PostG= google ( or Google market )
Try "apps2sd"
Don't forget to backup your stuff first (titanium back up app )
GoodluckCube T9 - Build v1.08 - OS v4.4.4 KitKat - Rooted.
LG G4 - OS v6.0 Marshmallow.
Dell Inspiron 15R SE 7520 i5 - Windows 10
Originally posted by Effinelus View Post
Now it all makes sense... I think. But why the mystery...
the mystery because you did not know what i wanted to say with "big Brother G" ,
of course i mean "Google" , hope you could find some useful Infos , what kind of
Tablet do you have , the Cube T9 or which one ??? , i have the T7 .
good luck / gefattern
There are currently 1486 users online. 1 members and 1485 guests.
