X96w / X96-w +/plus bluetooth Q5W2 V1.0 firmware / TWRP recovery ## S905W
    Dear folks, just received a X96w plus with bluetooth and I wonder if there is a TWRP recovery for this device?
    Recovery (universal): TWRP311_AML_S905-S912_ViT.zip
    Android 9 update:
    https://chinagadgetsreviews.com/down...ni-tv-box.html (wifi working! Bluetooth not working!)
    Is Tanix Tx3 Max compatible?
        Working recovery: TWRP vitmod same as for x96mini
        Unroot: flash unSU.zip through TWRP
        Anyone knows wether TANIX firmeare works with X96 ? I got the one with BLUETOOTH
          I have downloaded both x96w and x96w+ from the given link. First installed x96w and found that the kd player is not opening. But not a big issue because it can be replaced by Kodi 17.6. Anyway it is the original firmware. Afterwards I installed x96w+ and this also works pretty nicely. Kd player also works fine. Thanks for the link to x96w firmware. My search for x96w stock firmware ends here happily.
            Which one did you flash?
              Mine is without bluetooth; so I flashed X96-w.
                Tanix tx3 mini compatible ? with bluetooth available?
                  I confirm TANIX TX3 MAX firmware suits to x96w+. Just flashed this order:
                  1. TX3Max-20171228_bluetooth.img
                  2. TX3Max-Mini-p281-ota-20180125.zip
                  3. TX3MINI-171220-180305-ko.zip
                  Could pair PC and box but was unable to send data to box...
                  I will try some gamepads..
                    Snakebyte gamepad paired!
                      I have this error, Can somebody help me? I have x96w+ with bluetooth.
                      Please help me.
                      Enviado desde mi HTC Desire 820 mediante Tapatalk
                        Hi everybody,
                        Please, is there any one here who speaks or understands french? My english is horible.
                        I purshased an w96w android box and un fortunately some application dont turn well on it. For example, "my canal" doesn't work well cause i can't watch all the channels and i have to use a keyboard for this. Can i install on this machine android tv? Is there any risk? If it doesn't work, can i do a recovery and not lose my android box?
                        Help please!
                        Thanks a lot!
                          bien sur, mais ton francais est bien...
                          Essaie flasher firmware TANIX TX3 MAX!
                          Mais je sais pas si ATVexperience va marcher..
                            I have the x95w+ the one with bluethoot sameone has a copy of the stock rom for it?
                            In the site its not available.
                              If u are still interested I can give the link. Pl let me know
