MX10 ANDROID 8.1 OREO RK3328 4GB/32GB TV BOX FIRMWARE UPDATE R1 and R2
Originally posted by DaMeZ View Post
How did you install it??
Install driver assistant 4.4
Open rockchip batch tool 1.8
Put a toothpick in the av socket to hold down the reset button, plug usb male 4 into the pc let go of the button after a some seconds, then it says connected on the screen
Pick the firmware file (MX10 TV Box Firmware Android Nougat 7.1.2\MX10 RKMC18.0 20171212 r1.img)
Hit the upgrade button
and still stuck on black mx 10 screen
Originally posted by huniak View Post
According this instruction:
i had this version installed http://blog.geekbuying.com/2018/05/m...date-20180515/ maybe you can try flash this 1st then try again see if works..
i have MX10 4gb/64gb it has android 8.1 i want to downgrade to 7.1 noghat i got all driver and android on geekbuying 1st time it connected with factory tool 1.6 and it started upgrading when it goes 15% it failed after that my box just red light on nothing else no connected with computer i install alot of drivers but the factory tool not detect my box just red light on plz help me i am worried about my box because 2 month ago i bought it plz some one help me
hi i installed the new firmware MX10 Android 9.0 20190108.img at boot shows mx10 logo then green screen .. my box is 2018/05/18 does anyone know for which box is the new update for?
if anyone interested firmware its at http://blog.geekbuying.com/2019/01/m...date-20190108/
As Found Not tested MX10 ANDROID 9.0 RK3328 TV BOX FIRMWARE UPDATE 20190108
View article...blog.geekbuying:Glad to share the firmware for MX10 TV Box
Note: This firmware is suitable for MX10 4GB/64GB and 4GB/32GB TV Box.
PC Flash Firmware
Flash Tool
Flash guide, please refer to: http://blog.geekbuying.com/index.php...20/android-tv- boxes-flash tutorials-tool/
Have fun!
The post MX10 Android 9.0 RK3328 TV Box Firmware Update 20190108 appeared first on .
Originally posted by DaMeZ View Posthi i installed the new firmware MX10 Android 9.0 20190108.img at boot shows mx10 logo then green screen .. my box is 2018/05/18 does anyone know for which box is the new update for?
However, you will need to change your color profile to sRGB, which is insanely difficult to achieve when you cannot see what's going on.
Perhaps you might be able to use a regular AV cable and connect your box to the composite input of your TV and get an image?
Originally posted by Boullie View Post
If you get the green screen, the update was actually succesfull.
There are currently 2074 users online. 1 members and 2073 guests.
