Today I received my order (mk908II) and wifi signal is great, no restart( for the moment) but the only problem is that i tried to connect an 1TB external hard drive and appears a message "usb mass storage prepared" and then "select files to open.." so I click on that message and nothing happens/nothing appears to see the files on my HDD and i even tried with an memory stick 32GB but the same.
I even flash it with stock firmware and the results is the same...so this is a hardware problem or software?
And please tell on mk908II can i install a Finless Rom...?
Thank you.
*I managed to figure it out, seems that i needed to enter in an app to see the external hdd or others componets conected to the mk908II so after 3 hours of web surfing, youtube and so on i had no problem with the mini pc, no restarts and no wifi problems.
The only think is that on online streaming are some audio sync problems but i think that in the future with an software update or custom rom will be fixed.
