Intel Celeron J3455
ACEPC AK1 Mini PC is powered by the Intel Celeron J3455, a 64-bit quad-core processor based on the Goldmont architecture. The chip operates at 1.5 GHz with burst frequency of 2.3 GHz and has a TDP of 10 W. It also integrates an Intel HD Graphics 500 GPU and a dual-channel LPDDR3 memory controller.
Pre-installed Windows 10
ACEPC AK1 Mini PC is pre-installed with licensed Windows 10 home, so that our users are able to enjoy the advanced functions of Windows OS directly. Moreover, the built-in Cortana in Windows 10 can turn ACEPC AK1 into a work assistant as well as life-partner. With Windows 10 OS, you can sync game display to any devices of Windows 10 OS. What an amazing scenario! When your friends are watching football matches on TV, you can play games on Xbox and display on another PC screen.
4GB+32GB
AK1 is configured with 4GB memory and 32GB of storage space, advantageous in performance, security and reliability, ascribing to the eMMC memory, ultimately delivering a richer end-user experience.
Dual Band WiFi
With support for 2.4Ghz and 5Ghz band, it can transmit higher amounts of data, and it's naturally less congested.
Gigabit LAN
Gigabit LAN can improve the internet speed and the performance to a great extent.
Specification
General | Brand: ACEPC Model: AK1 Type: Mini PC Color: Black |
Hardware | OS: Windows10 System Bit: 64Bit CPU: Intel Celeron J3455 Core: Quad Core GPU: Intel HD Graphics 500 RAM: 4GB LPDDR3 ROM: 32GB eMMC Maximum External Hard Drives Capacity: 2TB |
Communication | WiFi: 2.4G/5G, 802.11a/b/g/n/ac WiFi Chip: intel AC3165 Ethernet: 1000M Bluetooth: Bluetooth 4.2 |
Media | Decoder Format: H.263, H.264, H.265, HD MPEG4 Video Format: 1080P, 4K x 2K, AVS, BD, H.263, H.265, MPEG4, VP8, VP9 Audio Format: MP3 Photo Format: BMP, GIF, JPEG, PNG, TIFF Support 5.1 Surround Sound Output: No |
Interface | 2*USB 2.0 Port 2*USB 3.0 Port 1*Type-C Port 1*HDMI 1.4 1*TF Card Slot 1*Earphones Port 1*RJ45 Ethernet Port 1*Lockwire Groove 1*DC IN |
Other Features | 5G WiFi: Yes Antenna: Yes DVD Support: No External Subtitle Supported: No HDMI Function: HDCP Language: English, Simplified Chinese, etc. |
Power | Power Supply: Charge Adapter Power Type: External Power Adapter Mode |
Dimensions & Weight | Product weight: 0.9570 kg Package weight: 1.1200 kg Product size (L x W x H): 12.80 x 12.80 x 3.65 cm / 5.04 x 5.04 x 1.44 inches Package size (L x W x H): 22.30 x 15.40 x 7.00 cm / 8.78 x 6.06 x 2.76 inches |
Package Contents | 1 x AK1 Mini PC 1 x Power Adapter(A right AC Adapter will be sent as your shipping country) 1 x HDMI Cable 1 x Bracket |
Coupon:IFEXMZKN
Buy now:https://goo.gl/r2nskp
