how to extract the DTB from MX10 RK3328 to use it with Libreelec?
How to extract DTB MX10 RK3328
Hello,
The File you looking for is in resource.img.
Use this tool for unpacking it https://mega.nz/#!RpBwRBiD!JQ5zjA1dn...ulsPznkmdXXbq4.
If you have a Firmware Image only then use Android Tool to extract the Firmware to get resource.img.
PHP Code:ResTool.exe [-unpack resource.img] [-pack <file1 file2 fileN>]
Example unpack: ResTool.exe -unpack resource.img
Example pack: ResTool.exe -pack rk-kernel.dtb logo.bmp subfolder\data.bin
Neomode
Originally posted by Gisbertg View PostNow i have the "rk-kernel.dtb". Rename to dtb.img and ready for libreelec?
Android uses 3.10 kernel, LibreELEC uses 4.4 Linux kernel.
It will never work.
Your device manufacturer has to ask LibreELEC to add support for your device and send samples to them.
You also have to submit patches for wifi, bluetooth, remote support to LibreELEC.
There are currently 1693 users online. 0 members and 1693 guests.
