Mecool M8S Pro L only supports Netflix in 1080p, not 4K. Also, Amazon Prime does not work. It is my understanding, the the Nvida Shield would serve your wants/needs, however I don't have one to confirm.
Hi, I have a TVbox TX92 with 2Gbram DDR3 / 16gbrom.
I am experiencing problems when I am a couple of continuos hours connected to internet by RJ45 cabling, the connection is lost (the device disconnects).
I have to turn off and turn on the TVbox to reconnect to Internet.
this is a bug ? Could you tell me how the bug is solved ? I need to updrade firmware ?
