I take no credit for these links. I just did the reseach to find them and wanted to compile it all in one place. I did however do this with my box flawlessly. I also hold no responsibility if you damage your box.
prerequisites and nessary files
1. a PC with internet access, on the same network as your box.
2. sd card format tool
3. SD card maker get it here
https://chinagadgetsreviews.com/down...er-v2-0-2.html
4. Amlogic flash tool
http://www.mediafire.com/file/3wd27i...cFlashTool.zip
5. custom recovery twrp
https://drive.google.com/open?id=1q5...zeq1CgbC6r-76K
6. poison rom 2.0
https://forum.xda-developers.com/dev...t/dl/?id=28724
the first part was tricky you have to make sure your firmware is for this unit. So i will save you the trouble of looking. Just download this firmware on your PC. Its the right one.
https://chinagadgetsreviews.com/down...us-tv-box.html
After downloaded read and follow this guide to make a SD card to flash the firmware you downloaded. (Read careful)
http://freaktab.com/forum/tv-player-...le-safe-method
after you have competed the steps and flashed your firmware your system should now be android 7.1
at this point connect to your internet and now follow the steps in this link it will put twrp custom recovery on the unit.
https://forum.xda-developers.com/and...-tool-t3745640
if all went well you should have twrp recovery now installed.and your ready for the final step.
1. Again format your sd card with rufus
2. Place the poison rom on the sd card.
3. Reboot box into recovery (twrp)
2. Perform a standard wipe(Click wipe, swipe to wipe)
3. Select install and install the Poison zip file on sd card (be patient)
4. Reboot and have fun
now you will be running the poison rom.
again i take no credit for this work or tools used here. Thank those on the links i provided because it was their hard work not mine.
for the poison rom info go here and thank him.
https://www.google.com/amp/s/forum.x...-t3751720/amp/
enjoy...
