M96X-II PLUS Amlogic S912 Android 7.1.2 KODI 17.6 2GB/16GB 4K TV BOX 2.4G/5G Dual Bnad WIFI Bluetooth4.0 1000M LAN LED Display
Android 7.1.2
M96X-II Plus is based on the latest Android 7.1.2 OS, with high speed and smooth, designed to turn your regular TV into a smart one.
Amlogic S912
M96X-II Plus comes with Amlogic S912 CPU which is a high performance octa core 64bit chipset which is known for a maximum clock speed of up to 1.5GHz. Apps will never run so smoothly in other chipset devices. People can easily enjoy many hot games and APKs with its 2GB DDR3 RAM and 16GB Flash ROM.
DDR3 2GB RAM, eMMC 16GB
Configure 2GB memory and 16GB of storage space, with smooth and responsive navigation and apps that launch quickly.
Dual Band WIFI
With support for 2.4Ghz and 5Ghz band, it can transmit higher amounts of data, and its naturally less congested.
1000M LAN
1000M LAN can improve the net speed and the performance to a large extent.
Specification
General | Model: M96X-II PLUS Type: TV Box |
Hardware | OS: Android 7.1.2 64Bit CPU: Amlogic S912, 1.5GHz,Quad Core GPU: Penta Core Mali-450 750MHz RAM: 2GB DDR3 ROM: 16GB eMMC |
Communication | WIFI: 2.4/5G WIFI, 802.11 b/g/n Bluetooth: 4.0 LAN:1000M |
Media | Decoder Format: H.263,H.264 Video format: ASF,AVI,DAT,FLV,ISO,MKV,MOV,MPEG,MPG,RM,RMVB,TS,VO B,WMV Audio format: AAC,AC3,MP3,OGG,WAV,WMA Support 5.1 Surround Sound Output: Yes |
Interface | 1 x AV 1 x DC Power Port 1 x Ethernet 1 x HDMI 2.0 1 x SPDIF 1 x TF Card slot 4 x USB2.0 |
Other Features | Language: Multi-language Other Functions: 3D Video KODI: 17.6 |
Power | Power Supply: Charge Adapter Power Type: External Power Adapter Mode Power Input Vol: 5V |
Dimension and Weight | Product weight: 0.210 kg Package weight: 0.440 kg Product size (L x W x H): 10.70 x 10.70 x 2.00 cm / 4.21 x 4.21 x 0.79 inches Package size (L x W x H): 16.00 x 15.80 x 8.00 cm / 6.3 x 6.22 x 3.15 inches |
Package Contents | 1 x M96X-II Plus TV Box 1 x Remote Control 1 x HDMI Cable 1 x Power Adapter 1 x English Manual |
