Cheap Chinese Box "M9C Pro 4K TV BOX" ORIGINAL FIRMWARE DOWNLOAD + SOME CUSTOM ROMS!!
    Post Made By NetherKingdom2
    Todays Date: Saturday, June 23, 2018
    Post Title: Cheap Chinese Box "M9C Pro 4K TV BOX" ORIGINAL FIRMWARE DOWNLOAD + SOME CUSTOM ROMS!!
    Now To Start The Post , We Will Talk A Little Bit About The Android Box:
    ABOUT THE BOX:
    Very Slow And VERY CHEAP ANDROID TV BOX WAS AROUND 25 USD WHEN PRICE WAS AVAILABLE , NEVER GET ONE OF THESE UNLESS U KNOW WHAT SLOW IS LIKE , ITS LIKE A TURTLE TRYING TO OUT RUN A CHEETAH SLOW, Box Runs Modified Android TV 6.0, AND THE ORIGINAL FIRMWARE FOR THIS BOX COMES PRE-ROOTED!!
    Backup Made On : Friday, May 11, 2018
    Backup Uploaded On : Friday, May 11, 2018
    Sorry For Making This Post Late, I Wanted To Do It On The 11th, But I Was Tired Then
    LINK TO BUY THE BOX:
    https://www.amazon.es/Bqeel-M9C-Pro-...zbestofda03-21
    SIDENOTE:
    I AM FROM USA BUT THAT WAS THE ONLY SAME BOX WITH A WORKING LINK!!
    THE HOW TO :
    1. Booting from SD card with the Reset Switch.
    2. Download the file twrp.s905x-3.0.2-0.img from this link https://www.dropbox.com/s/zfhu4xjk47...0.2-0.img?dl=1 .Then rename it to recovery.img
    3. Copy recovery.img to the root of your external SD card
    4. Put the sdcard in the m9c pro
    5. Power down your device
    6. Power up your device by pressing (and holding) reset button found in the AV port(for most amlogic devices) or on the bottom of the box (for the m9c pro) (you may need to open the box to get to the button, if pressing it doesn't work) (use a thin non-metal object - e.g. toothpick, plastic straw, etc)
    7. Your device will boot directly into TWRP
    8. Mount all of the partitions and mount the sdcard and wipe the whole box and restore the backup from the sdcard
    9. Reboot into system and enjoy!
    EXTRA FIRMWARE'S
    http://freaktab.org/ea9ed5ba904c416c (REMOTE DOESNT WORK UNTILL YOU COPY THE CONFIG FROM ANOTHER TYPE OF THE SAME BOX) https://www.youtube.com/watch?v=aSRcqO4IhH0
    https://drive.google.com/open?id=1iW...J_eu4F06yHobzo (M9C PRO 4K REMOTE.CONF FILE, AKA REMOTE CONFIG FILE)
    SOUND DOESN'T WORK UNTIL U PUT IN HEADPHONES , AND PICTURE MIGHT NOT SHOW ON MOST TV'S WITH THIS ROM, IF YOUR BOX HAS A BROKEN HDMI PORT
    This Rom Is Based From One Of The Xiaomi Mi Boxes And Is Modified To Include Other Features And Or Apps, Including A Root Feature That Needs To Be Enabled!!
    It runs android TV 7
    NOT TESTED(By Me At Least!!) :
    Another Rom:
    i had a friend who flashed the firmware using USB burning tool and everything seems to work better and faster, my friend says i am also not suffer from the dark picture issue anymore.
    Here is the link for the firmware below - USE AT YOUR OWN RISK
    https://onedrive.live.com/?authkey=%...126D253EA3A2B2
    DOWNLOAD LINK FOR ORIGINAL FIRMWARE:
    THE MOMENT YOU HAVE BEEN WAITING FOR:
    HERE IS THE ORIGINAL FIRMWARE IN A TWRP BACKUP I MADE, PS I MODIFIED THE APPS ON IT BUT I RECOMMEND YOU TO GO TO SETTINGS AND DO A FACTORY RESET, TO GET THE BEST EXPERIENCE.
    M9C PRO ORIGINAL FIRMWARE DOWNLOAD!! :
    https://drive.google.com/drive/folde...h9?usp=sharing
    AND I RECOMMEND TO DOWNLOAD THE FOLDER JUST USE http://jdownloader.org/jdownloader2 to download it all at once.
    ENJOY!!!
    I know that this post is really old but I need some help.
    I've download your backup files and the twrp, but the backup doesn't work...
    When I just copy the twrp folder on the SD card, I can't see the backup file... So I have try to make a backup with twrp and then I replace the file from my backup with yours.
    Then I can see the backup files and twrp copy it without errors but when I reboot the box, is like if nothing has happened...
    Are you sure that you use this twrp version ? Maybe I have forget something ?
    Thank you a lot
      take a pic of the m9c pro u have and is it a s905x and take a pic of the remote,ik theres a bunch of clones of them and most of the new ones have a diferent remote
