MK808B Help xbmc
MK808B Help xbmc
So i just got my mk808b and I have flashed it with the finless 1.7 rom. As I understand it after doing that I need to modify the advancedsetting.xml in the android\data\org.xbmc\files\xbmc\ but there are not any files there to edit. I have installed the xbmc from feb with hardware acell. not sure what I am doing wrong. any suggestions would be great. I am using ES File explorer to try an find the advancedsettings.xmlTags: None
The file is not there by default. Start XBMC once so it can create the folder structure. Then copy this advancedsettings.xml to "/android/data/org.xbmc.xbmc/files/.xbmc/userdata". Done.
PS: you may have to check "show hidden files" or something like that in your file explorer.
There are currently 2165 users online. 1 members and 2164 guests.
