The 10000mAh OUKITEL K7 is getting the first hands on video, full specs confirmed
    As the 5th monster battery smartphone of OUKITEL, OUKITEL K7 is worth waiting not only because of its long-lasting battery, but also its decent specs and price. K7 will go to market by end of May or early June, here we have got the full specs and global first hands on video of this device.
    Video: OUKITEL K7 first hands on:
    OUKITEL K7 is not an upgrading version of K10, but it improves a lot from the previous generation K10000 Pro. It gets a 6 inch FHD+ display with 18:9 aspect ratio and real leather back, 4GB RAM and 64GB ROM, octa-core processor and Android 8.1 Oreo OS.
    Processor: MediaTek MT6750T octa-core 1.5GHz
    OS: Android 8.1
    Display:
    Size: 6 inch FHD+, 2160*1080 resolution
    Touch: 5 points multi-touch
    Color: Black
    Cameras:
    Primary: 13.0MP+2MP, no interpolation, true-tone LED flash light
    Secondary: 5.0MP, no interpolated,
    Memory: 4GB RAM+64GB ROM, 64GB expandable
    Network:
    GSM: 850/900/1800/1900MHz;
    WCDMA: 900/2100MHz;
    4G FDD: B1/B3/B7/B8/B20
    SIM card type: 1 nano SIM+1 SD card;2 nano SIM
    Connectivity:
    USB Port: 5-pin USB port
    WLAN: Support,802.11 a/b/g/n/,Hotspot
    Bluetooth: V4.0
    Sensors:
    Press fingerprint sensor/ Gravity sensor/ proximity sensor/ Light sensor/ gyroscope sensor/ geomagnetic sensor/notification LED
    OTG: Yes
    OTA: support
    FM Radio: support
    Dimensions: 168*78*14.5mm,weight:302.5g
    Battery: 10,000mAh, 9V/2A charger
    Monster 10000mAh battery, large 6 inch 18:9 long display, big 4GB RAM and 64GB ROM flash memory, OUKITEL K7 combines large battery to a simpler yet elegant design.It will be sold around $180 for retail, but OUKITEL started a subscription activity to offer unveiled surprising coupon code to get lowest price. What’s more, 3 lucky subscribers will get the chance to buy K7 at $99.99. Are you interested in this new 10000mAh battery smartphone? Subscribe it here: http://www.oukitel.com/activity/activity-43.html
    http://oukitel.com/
