Ugoos UM2
    Ugoos UM2
    Just received this stick, and while being awesome (better design than previous sticks, smaller PCB, two USB host ports), it has a few kirks. For one, there is no OTG on the OTG port at all, I cannot even get to be recognized. Does anyone have any idea?
    Images:
    No worries Bro this Device has an OTG Port, but the Chinese Way
    What you need is a Cable with a USB Connector Type A to Type A.
    The Wiring is one to one.
    I know this is no Standard Cable, may you can make it by Yourself.
    Neomode
      Neomode
      Yes I can but I still don't understand why not to use the microUSB port. Is it even possible? I took a few shots of that port, but I cannot see any actual connection to the data pins, only the power and ground were pulled up (though I might be wrong, especially if this is a layered PCB and the microUSB is routed in an inner layer).
        AW: Ugoos UM2
        Maybe I don't have this Device here.
        But look you only need this Cable for flashing. I don't would do a re routing of the Data Pins.
        I don't know why Ugoos have make it like this :banghead:
        Neomode
