unloading non-essential modules: SOLVED
I have been trying to unload non-essential modules that are loaded on startup with hfw 1.2.2 by lewy. I have tried rmmod and modprobe -r with no success. I have even gone into the lib/modules directory and still the modules will not unload. Does anyone know where the script is located that pre-loads the modules upon startup? Usually I use a script in init.d for all my modules but I didnt see a 01xxxx script there.Last edited by Gfunk; 07 September 2013, 22:26.Tags: None
I was just thinking that maybe perhaps kernel module unloading is not configured in the kernel .config for wassers kernels. Checking .config for support...
Unloading support is built into the kernel:
CONFIG_MODULES=y
# CONFIG_MODULE_FORCE_LOAD is not set
CONFIG_MODULE_UNLOAD=y
CONFIG_MODULE_FORCE_UNLOAD=y
Good you found solution for your problem.
For now all modules are insmoded from boot.img init.rc.Everything is possible if we work together!
There are currently 2596 users online. 3 members and 2593 guests.
