A95X PRO Android TV Box with Voice Control
    Thanks to Gearbest we can have a look at the
    Another in the 905w series that has HD Netflix etc,
    Good looking unit, BT Dongle Remote
    Let's have a closer look.
    The Box
    Whats in the Box
    Ports a close look
    Remove the Base
    Couple of screws out with PCB
    and the bits that make it happen
    Gearbest
    Those with Netflix, bar at bottom of screen:
    The fix:
    The grey bar in Netflix is due to the ROM not disabling the virtual softkeys.
    Add qemu.hw.mainkeys=1 to the build.prop file (you'll need to enable root access in Settings) and reboot to get fullscreen Netflix
    Source:
    http://freaktab.com/forum/tv-player-...769#post726769
