Need Root for next7p12 (m3-chip)
    Is there root for my tablet next7p12 (m3-chip)?
    Cydia impactor will root this tablet
      How can I use it? & find the root?
        MagicRom1.1 for next8p12 (amlogic chip)
          Sorry, I don't know how Cydia Impactor works, but it is easy to find. Just search the web for "Cydia Impactor".
          ShaunMT
          Freaktab Rom Developer
            http://www.freaktab.com/showthread.p...2-Rom-MagicRom
            The OP asked about a Next7P12 (Amlogic Meson 3). The Next8P12 (Amlogic Meson 3) ROM is not likely to work, as the screen sizes are different.
            ShaunMT
              ShaunMT
              Works by exploiting a vulnerability in google's app signing master key
                Well played... what I meant was I haven't used it, so I can't provide instructions. I think the author has a website with step by step instructions though.
                  You're absolutely correct, he has a very detailed write up about how it works and how to use it, but basically all you do, is have the ADB drivers installed and working, run impactor, select drop su into system/xbin and press go and you got root, next step is to install superSU or superuser apps to update the su binary
