Zidoo X20 RT-1296DD 2/16GB AC WiFi Gig Lan BT4.1
    a
    Functional overview
    * 430mm Standard cabinet Size, All aluminum alloy chassis
    * New upgrade version Realtek 1296 Quad-Core 64 bit A53 processor, High quality high-power SMPS.
    * 2G DDR4 Memory, 16GB eMMC Super Built-in Storage,gigabit wired, 802.11 AC 2T2R 867Mbps WIFI, Bluetooth 4.1
    * Abundant Interface:SATA3.0*2, USB 2.0*2, USB 3.0*1, TYPEC *1, Coaxial Cable*1, Optical Fiber*1,
    Left/Right Channels*1, AV Output*1, Infrared Input*1, RS232*1, HDMI OUT*2, HDMI IN 2.0*1
    * Full function with backlight Bluetooth-Infrared-Learning three-in-one remote control, remote control without dead Angle.
    * Super Lager front LED Display.
    * Independent Dual SATA 3.0 Ports, NSS Patented metal hard disk extractor can Build-in two High-Capacity Hard Disk.
    * Smart temperature control with dual Balls and High Static Pressure Fan.
    * Dual HDMI output Audio and Video separation, without upgrading the original amplifier, the old generation
    of power amplifier function 4K and HD Audio too
    * New quality optimization engine technology, Optimized HDR to SDR Algorithm. Play 4K HDR which
    Restoring primitive color even without HDR TV.
    * Detailed Frame switching and resolution switching. (23.976,59.94,25,30,50,60)
    * 4K 60P Point to Point Output, Color Region: HDR/HDR10, 10Bit Color Depth, 10.7 hundred million kind of colors.
    * True 4K 60P decode, H.265/HEVC 10Bit Hard solution.
    * Support 4K UHD Blue-Ray Navigation
    * Powerful subtitle function, Support random change any fonts with different color effects; Support
    download subtitle online; Support SUP&ASS special effects subtitles
    * Unparalleled Wall-Poster Function, Full automatic scan, Automatic classification and sorting movies and dramas. Customer Layout.
    * Break the Android SRC limitation, and the audio adoption rate maximum supports 192K output;
    * Soundtrack support SACD, DFF, DSF, APE, FLAC, WAV and etc Free lossless audio formats;
    * Support CUE track; Support cell phone control without having to open the display device to listen to music.
    * Support NFS, SMB, V2, SMB V1 multiple shared protocols.
    * Support HTTP, RS232(Control on-off), Control4 Multiple ways to control.
    ZIDOO
