I made (or tried to) a custom Android TV firmware for my MXQ-4K based on the Ugoos 1.2.0 firmware (which is a 6.0.1 Android). Installed everything and it run very good (some things as the Chromecast built-in and Live Channels didn't work, but I don't need it too much). My Google Play Store only install or update apps if it's version 6.8.24 or bellow (which I found yesterday that is the version who target SDK 23) and my Play Store keeps updating itself to the last version and with it comes the "Install Pending..." whenever I try to install any app. I installed Aptoide TV but it doesn't have the Google Apps to update. What can I do?
Play Store stuck on "Install Pending..."
Hi.
I made (or tried to) a custom Android TV firmware for my MXQ-4K based on the Ugoos 1.2.0 firmware (which is a 6.0.1 Android). Installed everything and it run very good (some things as the Chromecast built-in and Live Channels didn't work, but I don't need it too much). My Google Play Store only install or update apps if it's version 6.8.24 or bellow (which I found yesterday that is the version who target SDK 23) and my Play Store keeps updating itself to the last version and with it comes the "Install Pending..." whenever I try to install any app. I installed Aptoide TV but it doesn't have the Google Apps to update. What can I do?Tags: None
did you clean all the Google Apps before / cache / data / or try to wipe
cache and dalvik from all Apps , reboot & try again .
Maybe it helps , good luck / gefattern
Hi ,
Tried everything. I found out that it was the firmware's fault. I'm trying now with a 7.1 firmware, but now I get a Leanback Launcher stopped working error.
the new 7.1.2 Roms are still full of Problems , Launcher install is difficult & your Launcher is a special TV Rom Launcher ,
search for "leanback launcher" on big G , the first Link is a XDA Link with , i hope , useful Information for you .
Hope you get your Rom working , good luck
greetings / gefattern
Hi ,
Do you know if there's any 7.0 roms to the RK3229? Tried some search yesterday but only found 7.1.2 roms.
Thanks, going to try this launcher!
i dont think so , i believe Rockchip started with 7.1.2 , but not sure , but at the Moment there are so
many RK3229 Boxes & Roms , if you know what Wifichip you have there is maybe a chance to find
a well working Rom .
There are currently 1777 users online. 0 members and 1777 guests.
