how i could flash via phoenixsuit???
    Hi guys
    Sorry for my noob question but i didnt find a post with detailed steps how to flash via phoenix suit for draco aw80. Maybe is simple enough as describe it here https://androidmtk.com/use-phoenix-suit-flash-firmware. But i dont know how to start device in recovery, if need it, as i dont know where is the reset button. Also i get this error for android wpd, as you could see in photo. in first place was google inc too, but i fix it with this topic http://www.ondaforum.com/topic/1813-...ers-in-win-78/. Please any tip would be more than great
    Thanks in advance
    You will need phoenixcard:
    If you are talking about a tronsmart aw80
    https://drive.google.com/file/d/16vy...epiq5u5M0/view, should be fine
    Run the PhoenixCard.exe file
    From the drop-down box, select the microSD card, click DiskCheck, and tick the Product.
    Click on Img File and select the firmware file that you downloaded from the link above.
    You can press Burn and wait for the end of the recording, then you should safely remove the memory card.
    Disconnect box the network, disconnect all devices from it to USB and turn off the power.
    Insert a memory card, connect to a monitor or TV, and power up. The installation process starts with the green bar, wait until the end, then turn off the power and remove the memory card, then you can turn it on and on again.
      Hi Trebor
      Thanks for your infos! I never tried to a flash a rom as you replied, because i got a new one. i am planing to use this tronsmart draco aw80 to my little daughters room to watching cartoons. I will appreciate if you could suggest me which rom is better to update, as i see in topics you have tested them all. It still running on same firmware that it came.
      Also notice @ https://www.tronsmart.com/blog/21_dr...firmwares.html a new firmware 151117_update, was it a last try from tronsmart for a better firmware? As it appearing to be [posted on January, 24, 2018. Do you have any opinion?
      Thanks in advance
      • trebor
        trebor commented
        Editing a comment
        Not used this Unit in a long time, if its working Ok I suggest leave it
      thanks
