Hello I ask your help please.
I have a H96 pro plus 3 / 32GB. She is blocked on the "recovery mode". The remote control is not recognized nor the mini keyboard. I can not move on the menu. I pressed the reset button several times but still the same problem. I just want to restart my box.
Please help.
If You disconnect power cord and connect it again, does it boot to recovery? Without pushing the reset button? It may mean that reset button is broken, or that eMMC memory got broken and boots only available partition.
The Best you can do is to reflash the Firmware on your Box to bring it back to Live.
For this, you need your Computer an USB A to A Cable and the USB Burning Tools.
Than You should try with shorting the pins. If even that won't let You to connect to PC and flash the firmware it may be unbrickable. Maybe AC has to high voltage output?
Today, the box does not even start on recovery mode. No lights. I think I found the origin of the breakdown. Apparently I mistakenly plugged it with a 9V power. I am very very sad. I only used it for 02 months
