HELP ! Bricked UG007b
    Hi Guys.
    Recently I've bought an ug007b from AliExpress.
    I was updating his firmware, using Rockchip Batch Tool.
    When the Batch tool restarted the device to start flashing, the device simply disconected, and now I cant put it on recovery mode anymore.
    When I plug the usb cable, the red led on the board lights, but plugging the device wont conect it to pc.
    Is there anything I can do ? The device has an RK3188 chip.
    Thanks in advance.
    Hello,
    What you can do is to make a Nand Reset.
    For this you must Short Pin 5-8 on the Left Side of your Nand Chip.
    Then it should Work again.
    Neomode
      Originally posted by neomode View Post
      Hello,
      Neomode
      Hi Neomode.
      Thanks for the reply.
      To do this, I have to link the pins 5 and 8 togheter?
      My device is identical to this one :
      Nand Chip Photo : http://storage.superconnected.org/img/qc802-1.jpg
      Rockchip Photo : http://storage.superconnected.org/img/qc802-2.jpg
      Thanks again.
        Hi !
        Just to inform that I've managed to revive the device!
        A friend of mine managed to do the Nand Reset for me.
        I was all based on what Neomode told me.
        Thanks!
