FAKE UNROOT / XPOSED / MAGISK MANAGER FOR BEELINK GT1 ULTIMATE KERNEL VERSION 70XD0.
    NOTE 1: DO IT AT YOUR OWN RISK!
    NOTE2: DO NOT ADVISE INSTALLATION IF YOU USE THE ROM STOCK.
    Sorry for bad English, because I used google translate.
    First of all install the ROM ALVATECH available at the link: http://freaktab.com/forum/tv-player-...-roms-tools-ch / 722668-rom-beelink-gt1-ultimate-android-7-1-2-alvatech-ddr4-newer-boxes
    Installation tutorial included in the official ALVATECH topic!
    FAKE UNROOT
    1st: Install Apk magisk manager and follow the installation tutorial of the zip file via twrp available at: https://magiskmanager.com/
    2nd: Enable Magisk Hide and in the list of applications select the applications you want to hide root.
    3rd: Go to settings> apps> HBO GO "EXAMPLE" and clear the application data.
    4th: Open the application and be happy!
    Xposed
    1st: Open the magisk manager and in the side menu select "Downloads".
    2º: Search the module: Xposed Framework SDK 25.
    3rd: Select the module and will open a sub tab with the link to download the apk xposed installer exclusive to the magisk module.
    4th: Download and install the apk, and then download the module by clicking ↓.
    5th: Enter recovery mode by pressing F8 or using the power menu.
    6º: Flash the .zip of the module xposed, clean the dalvik / cache and restart the system.
    7: Install the frameworks you want straight from the Xposed installer.
    Note³: All magisk / Xposed modules tested by me have worked 100%.
    Any doubt I am available !!!
    Credits
    ALVATECH for best custom rom
    Topjohnwu for Magisk Manager
    ROVO89 for Xposed
    Me for simple tutorial.
    User Sample17 blocked. We will not accept this sort of advertising/spam and more than likely malware on FreakTab.
