X99 4GB/32GB RK3399 4K TV BOX FIRMWARE UPDATE 20180323
    Originally posted by GeekBuying_Rep View Post
    hi friend,
    Maybe you can try this.
    http://blog.geekbuying.com/2018/06/x...date-20180522/
    Hi Geekbying Rep ,
    & all others , first want to say thanks for new upload , i already
    downloaded & flashed the Rom , User Trebor uploaded temporary
    on Mega , thanks for this to Trebor too , but if i try to update the
    "su Binarys" , it fails , offline & online , why does this happen ??? ,
    can this be changed ??? ,
    and is there any chance to fix all this translation errors , i am from
    Germany and there are still so many English parts after changing
    to German , small Example about all this Errors , if you setup the
    Box & want to select German , you can see the German Flag , but
    under it stands not German , it stands something like :
    "Aufrechtzuerhalten" , this has nothing to do with correct , this word
    mean : to hold something in the same state ,
    that is only one Example , i really want to help , i can make a txt.File
    for the Developers , with all Corrections in German , i be sure it is the
    same with other Languages , and i know that even you would prefer a
    nice translated UI on the Devices you use .
    Please i really want to help with translations and i think other Users
    with other Languages too , with a little bit support from both sides
    we can make the next following Rom much better .
    greetings / gefattern
      Hi ,
      one more strange behavior :
      look at my two last Posts , thanks for helping ,
        Hi Geekbying Rep ,
        hello friend,sorry for late response.But I am not so clear about your meaning.
          Hi ,
          first thanks for "rooted" Rom , BUT the SU Binarys can not be updated ,
          does not work and the Rom is full of translation Errors and not translated
          text , another Problem is , after Shutdown/PowerOff , there is still Power
          on both USB Ports , my Fan still runs after Power Off , that is not correct .
          No Screenshot Settings / in more Settings the Brightness does not work /
          and if you want to uninstall or clean Data&Cache in atvSettings , some of
          the frames only react if you press on beginning (in front of word "OK" or
          on the end of the frame) , no reaction in the middle of frame ,
          that is all for now .
            Hi ,
            hello friend,thank you for your info.We will tell the supplier about these problem.
            the SU Binarys can not be updated ,does not work
            If you can send us a picture of this problem,it may help a lot.
              Hi ,
              thanks for answer , if the SU Binarys can not be updated , the SU in Rom is not good
              programmed , but i am no Dev. , another Problem is the PowerOff , with stock the Box
              has still Power on USB & Display is off , if i use the App Reboot from Dev. Petrus , the
              Display still works after PowerOff & USB ports have Power too & the Box can then only
              be booted by pull & plug the Power new .
              What about Magisk will this work ???, try to make some Pictures and load them up later ,
                Hi ,
                hello friend,please send me some pictures.Sorry for inconvenience.
                  Hi ,
                  first , i think that a Picture not can show that the Power is still on after Shutdown ,
                  the translation Errors can be shown on Pictures ,
                    Hi ,
                    found more Bugs , the RecentApps have no close Button (all) & if u want to close them
                    one by one and press the small (x) under the App , it opens and not close , the worst is
                    u can not uninstall one stupid not needed SystemApp , even preinstalled Apps can not
                    be deleted , i always delete this not needed Apps and some more , now i can not use
                    the Box as i thought it is possible , with "root" .
                    Why "root" does not work correctly , why we all can not update our SU Binarys , until
                    now possible with every other Typ "rooted" Device ???
                    gefattern
                      Hi again ,
                      want to report that uninstalling works well , i had to take another FileBrowser ,
                      but the Rest must still be fixed , / gefattern
                        Hi again ,
                        hello friend,thank you for your info.Is there any other question? We will tell the supplier.
                          Hi ,
                          tonight i upload some Videos that i made , that you see the Bugs , and i made Screenshots , with
                          them , i send in a few Days a txt.File with the correct Translations and spelling fixes , then the Devs
                          can fix this things too , okay ,
                          greetings gefattern
                            Hi ,
                            one more Info , the PlayStore often gives a crash Report , most after using him and closing him ,
                            greetings gefattern
                              Hi ,
                              one more for sure Daydream is not working , different Time sets in both Settings , really ,
                              confusing ,
                              greetings gefattern
                                Hi ,
                                please look this :
                                hope you so correct to delete it after u not need it
                                anymore ,
