Duplicate Box
Originally posted by t23 View PostYou want to factory reset the bad one before returning it, or? In TWRP under Wipe, there's an Advanced Wipe. If you pick Dalvik, Cache, Data and Internal Storage, swipe, and then pull the plug and pack it up, it's good to go.
Originally posted by t23 View PostThe driver is called 4335, and a quick Google for that shows a Broadcom device that is indeed a combo device - in fact, it also has FM radio.
Oh well, if they don't want it back, you can always use it as a spare - or as you do now, use it for learning.
Originally posted by t23 View PostIf the KB2 is a q20x then most likely, otherwise no. TWRP is board dependent, it's not just about the processor. There are probably way better apps for the purpose, but i use one called AIDA64 - it gives you nearly all the system info you need.
There are currently 1928 users online. 0 members and 1928 guests.
