Version:v2.0.25
Update list:
System
1. Solve the flashback problem with Raytheon iii at 1:55:00
2. Added the HDMI sound output shutdown function
3. Optimized online video playback
4. Added theme switching for desktop and ZIDOO applications
5. Fixed the problem of no sound on the DTS-HD audio track for some films
6. Fixed the problem of playing some video occasionally green screen
7. Optimization of small offset of 23.976 frame rate in some resolution and color depth modes
Shortcut
1. Added Subject ambiguity and mask Settings
2. Added HDMI sound output switch
3. Added player custom key Settings
Wall poster
1. Added wallpaper features
2. Optimized the scoring accuracy
3. Optimized the setting interface
4. Matching source adds DouBan interface
5. Home ordering increases the modification time of receiving files
6. Optimized the matching of domestic TV dramas
7. Optimized the stability of scanning
8. The problem of optimizing partial DouBan data without obtaining the film name
9. Press the play button of the remote control to play the film directly in the poster details interface
10. Optimized the processing logic if the background is scanning when changing the language
11. Enhance the relevance of characters and solve the problem that douban characters cannot relate to films that have not entered the details
12. Fixed the problem that the sorting parameters of the classified screening interface of the poster service are not effective
13. Added year parameters when matching
14. Increased data source selection when rematching
15. The issue of flash back in certain special cases when repairing scanned posters
16. Fixed the problem of inaccurate search in the search interface
17. Optimized children's lock function
18. Optimized the main interface prompt
19. Optimization when updating the device or background scan, the failed match and the cleared video will be forced to rematch
20. When opening the child lock, the edit poster must pass password verification
21. Optimized permission detection when adding devices
22. Add the TVDB interface
23. Optimized the file manager to view the poster function directly
24. Optimized the display of multimedia labels
25. To solve the problem of inaccurate year selection in the classification and screening interface
26. Optimized UI display
27. Optimized poster display speed
Startup Wizard
1. Modify the UI and synchronize the system theme
Blu-Ray navigation
1. The frame rate switching function is synchronized with the normal playback mode
Music player
1. Fixed the problem that the machine will go to sleep when music is played
2. Added the shortcut function of the remote control (top, next, play/pause, stop, cycle mode, etc.)
3. Fixed the problem that cannot be saved after the playback mode and sound effects are restarted
4. Added DSF, DFF, SACD ISO music support
File manager
1. Fixed the problem of choosing NFS devices to report errors when there is no networkplayer
1. Optimized the continuous play function of serial series on poster wall (all cyclic play functions need to be turned on for serialization)
It is suggested that you clean up the hometheater(poster wall) 2.0 data after upgrading
Download:http://ota-cloudfront.zidoo.tv/X9S/O...1805241435.zip
MD5:2967ed7900b322230c60014a0fab636b
How to upgrade
source:zidoo
