They have all included the sam321 fix for video some new governors and io schedulers and some improvements made by phjanderson, sam321, thesawolf, hoaby, Galland, omegamoon, etc... Thanks to all of them, specially to phjanderson for his great tool marvin, with it is a lot of simple compile kernels with a lot of options enabled, and sam321 for his video fix and oc code.
I use ondemand like default governor, and default IO scheduler is noop, you can change it with any cpu control app like No frill cpu control, Antutu CPU master, cpuspeed, etc...
I made 10 kernel:
kernel_20130909_163218_leolas_qx1_1080p_vsfsam_cpu 1800_ddr600.img
1080p; sam321 video skipping fix, CPU Overclocked to 1800mhz maximum.
kernel_20130909_163218_leolas_qx1_1080p_vsfsam_cpu 1800_ddr720_gpu798.img
1080p; sam321 video skipping fix, CPU Overclocked to 1800mhz maximum, RAM overclocked to 1440Mhz GPU overclocked to 798 Mhz maximum.
kernel_20130909_163218_leolas_qx1_1080p_vsfsam_cpu 1920h_ddr720_gpu798_cfgia.img
1080p; sam321 video skipping fix, CPU Overclocked to 1920 mhz maximum (cpu speds only 1200, 1608, 1800 and 1920 mhz enabled), RAM overclocked to 1440Mhz GPU overclocked to 798 Mhz maximum and more aggressive interactive governor (by default is used ondemand).
kernel_20130909_163218_leolas_qx1_1080p_vsfsam_cpu1 920h_ddr720_gpu798.img
kernel_20130909_163218_leolas_qx1_1080p_vsfsam.img
1080p at default speeds with sam321 video skipping fix.
kernel_20130909_163218_leolas_qx1_720p_vsfsam_cpu1 800_ddr600.img
720p; sam321 video skipping fix, CPU Overclocked to 1800mhz maximum.
kernel_20130909_163218_leolas_qx1_720p_vsfsam_cpu1 800_ddr720_gpu798.img
720p; sam321 video skipping fix, CPU Overclocked to 1800mhz maximum, RAM overclocked to 1440Mhz GPU overclocked to 798 Mhz maximum.
kernel_20130909_163218_leolas_qx1_720p_vsfsam_cpu1 920h_ddr720_gpu798_cfgia.img
720p; sam321 video skipping fix, CPU Overclocked to 1920 mhz maximum (cpu speds only 1200, 1608, 1800 and 1920 mhz enabled), RAM overclocked to 1440Mhz GPU overclocked to 798 Mhz maximum and more aggressive interactive governor (by default is used ondemand).
kernel_20130909_163218_leolas_qx1_720p_vsfsam_cpu1 920h_ddr720_gpu798.img
kernel_20130909_163218_leolas_qx1_720p_vsfsam.img
720p at default speeds with sam321 video skipping fix.
I hope this kernels can satisfy all options, for those who want no overclock, a slightly overclock and aggressive overclock. Remember that not all processors will work with overclock, and with overclock you can need a better power supply and heat dissipation.
Like always flash them under your own responsibility, bla, bla bla. I tested them and all works for me.
If someone want to compile his own kernels, I use to compile them phjanderson sources, a little modified to fit in my requirements, I upload the sources to my github and added them marvin tool (made by phjanderson). Inside the zip there are all the .config files used to compile them.
Sources:
phjanderson sources: https://github.com/phjanderson
My github: https://github.com/leolas/rk3188
Of course if any developer wants to use any of them in his roms, use them without problems
leolas
