I got a trouble of rooting my MX9 Pro TV Box. I want to install a VPN app, which needs a rooted device. I spent a whole day yesterady to search how to root rockchip's device, but found nothing.
I tried using Kingroot to root it, but failed. Finally, I found some threads which is discussing about TWRP and SuperSU or Magisk.
The main problem is that installing SuperSU through TWRP requires "unlock bootloader". When i used adb command to make my device into "bootloader mode", it became to black screen and nothing happened. Tried several times, but i got the same result.
I also tried making it into Recovery mode, but seems nothing to do in this mode. When i selected "reboot to bootloader", black screen again and nothing happened. I have to unplug the power cord and replug to make it ON again.
Does anyone know how to install TWRP.img for RK3328 device as MX9 Pro or How to root this device? Has visied TeamWin - TWRP site, but can't find the corresponding TWRP.img for my device.
Someone seems successful to install TWRP in A5X. I tried to follow the thread, but still failed. When using the Android tool, an error message "Match device type failed, stop running" shown after clicking run button. I'm not sure if i should make the device to be Maskrom mode? but i'm not to flash the firmware, i just want to install TWRP recovery.
I was very frustrated by this... Can anyone provide solutions to me.
Thank you.
