First post new to forum. Had a couple of other boxes, but I have an issue with my current box. The version that I have does not have the LB or the voice remote. I do have an ambolove 2.4 ghz keyboard dongle in 1 sub slot. The problem that I am having is that the IR remote only works intermetently. It will work sometimes and not all of the time. Sometimes if I unplug the box for a couple minutes and plug back in it will work for a couple minutes and stop again. Sometimes it happens right after boot up so I don't believe it is a heat issue necessarily. I have contacted the seller where I purchase the box . they've agreed to send a new remote. I have also tried unplugging the keyboard dongle. Sometimes it works but then it will just stop. Do you guys think it's a problem with the remote? Or do you think it could be the IR sensor Inside the Box? Thanks for any help and glad to be a part of the forum.
M8S Pro L 16gb remote problems
Hi everyone,
First post new to forum. Had a couple of other boxes, but I have an issue with my current box. The version that I have does not have the LB or the voice remote. I do have an ambolove 2.4 ghz keyboard dongle in 1 sub slot. The problem that I am having is that the IR remote only works intermetently. It will work sometimes and not all of the time. Sometimes if I unplug the box for a couple minutes and plug back in it will work for a couple minutes and stop again. Sometimes it happens right after boot up so I don't believe it is a heat issue necessarily. I have contacted the seller where I purchase the box . they've agreed to send a new remote. I have also tried unplugging the keyboard dongle. Sometimes it works but then it will just stop. Do you guys think it's a problem with the remote? Or do you think it could be the IR sensor Inside the Box? Thanks for any help and glad to be a part of the forum.Tags: None
Welcome to. I'm just gonna bump this topic, because i have issues with that remote as well - although an entirely different issue.
See, i have both a KM8 P and an M8S Pro L, which came with the same IR remote - the black one with grey and blue buttons. On both boxes, regardless of if i'm using a VS firmware or a Magendanz firmware, i have some really strange behaviour with that remote.
If i press "left" on the blue navigation ring between 10 and 20 times in a row, the boxes do a graceful shutdown. Pressing "left" on a keyboard or a gamepad do as expected, it is only the remote that does this.
Now, what makes it do a thing like that?
I ended up getting sent the Yoka TV KB2 (not the pro version with 3G Ddr 3). Much better box and remote. I will consider buying the pro version I like the one I have so well. Even the seller said the 16gb version of that box is sketchy. Apparently the bluetooth voice remote is a better performer.
Sent from my SAMSUNG-SM-G930A using Tapatalk
There are currently 2094 users online. 0 members and 2094 guests.
