MXQ PRO+, spdif port has no red light and no sound? how to fix? Settings?
    Hi I got a MXQ PRO+, I don't know what board it has.
    it's this one: https://www.geekbuying.com/item/MXQ-...GB-385604.html
    But my spdif port is not working, there is no red light coming out at all, and of course there is no sound coming out.
    Does anyone know how to get that spdif port working? maybe with red light coming out? through settings?
    I'm really desperate, as I got two of them both have no red light coming out.
    Thanks a lot.
    I think you will find if it has no door on the SPDIF if uses a 3.5mm to RCA cable not Optical, no red light
      Thanks for the quick response... but what does it mean no door? do you mean spdif it's the circle one? with no cover?
      The square one optical with cover?
      My knowledge on this is very limited. I bought a spdif to optical cable (in picture), but I think without the red light it's not going to work.
      how does digital sound transfer by fibre work without light?
      I thought the spdif should work like in this picture... does it mean there are different type of spdif port?
        my speaker system only has one of this port, works with my ps3 and ps4 which are all optical with red lights.
        So how can I get the sound directly to my speakers, in digital format would be the best, so output sound still has DTS (digital) etc instead of Dolby Pro Logic II (this is not digital, correct?)
        Again, my knowledge is very limited. Sorry if I got it wrong. Please correct me, much appreciated.
        Thanks a lot.
          I think your model uses cable I have mentioned looking at the picture of the box.
Name:	MXQ-PRO--Android-7-1-2-Amlogic-S905X-4K-TV-BOX-2GB-16GB-Black-20170909144420587.jpg
          Normally If it has Optical SPDIF these media players it has a small cover/door and the cable is Square both ends,
          Newer units are using cable like the one you have pictured but normally not on these media player or as I have seen yet.
            SPDIF CONNECTIONS EXPLAINED
            SPDIF is a standard for transmitting high-quality digital audio without going through an analogue conversion process. It is used for connecting Hi-FI Equipment, DVD players, CD players, Mini-Disc Players, Sound cards etc.
            The SPDIF interface can be implemented in two different ways “coaxial and optical”
            Coaxial
            This interface uses RCA phono connectors and 75 Ohm coaxial cable.
            Optical
            This interface uses fibre optic cable and is available with two types of connectors - TosLink (shown left below) and Mini Optical (shown right).
            Mini-optical connectors are sometimes called Mini-Toslink, MiniPlug or Mini Optical jacks, but they all refer to the same connector, as pictured above!
            The mini-optical connector is typically used on portable CD and MD players, but it is also used on other audio devices. The TosLink connector is commonly used on DVD and CD players, DAT recorders, surround sound receivers etc.
              Thanks a lot for the explanation. I got tears in my eyes when I saw that, why they use same name for two different things. Just confuses people. T_T
              Anyway, obviously I got the player for the wrong reason. So how can I convert coaxial which has no light to my optical input speaker system which uses the red light?
              Do I need a converter or something? with the power source I guess? to generate the red light?
              Thanks a lot.
                I see some converters here
                Have not used may help, maybe cheaper/ to get box with optical.?
                  I couldn't find any box can delivery to me with optical port when I bought mine.
                  Only a few ones with spdif, and I thought spdif is as same as optical, which a lot of internet articles suggests. So wrong that turned out.
                  I think most of these boxes are going for cheap, instead of functions or quaulity.
