We do not need data or cache. But he did give me boot.img and system.img AND they work!
I am able to easily mount them in Linux.
So I have looked at boot.img and I can now easily change init.rc to give you guys permanent root. I can also inject Google Play directly into system.img. These images are standard ext4 mounts.
However I have not learned yet how to flash or even if you can flash part of a ROM like boot.img or system.img alone? You can probably use ADB to push the new images?
As far as a ROM goes, based on reading so far, you must make a ROM and flash the entire thing. You make a ROM using the tools. To do that we will still need rootfs and recovery I think?
Anyway I will have his boot.img and system.img uploaded for you all to download from here so you have them. If someone can figure out how to flash or even puch the new images I can easily now make you guys a custom boot.img and system.img!!!
Here is the download for Notpod's dump of boot.img and system.img
http://video.freaktab.com/?subpath=f...and_system.zip
