I originally purchased the Measy U2C-D dock from Geekbuying and was excited about its prospects. I received it DOA and knew it would take an effort to get it replaced and/or a refund (which after 5 emails back and forth for a month with Geekbuying I finally got a refund). While waiting for a resolution, I decided to put my own docking station together using easily obtainable parts.
Components:
USB hub with ethernet port ($20)
USB extension cable ($6)
HDMI extension cable ($8)
USB on/off dongle ($2.50)
Both extension cables were bought so I'd have the flexibility for dock placement.
Findings:
- Ethernet connection via the hub works great
- HD USB plugged into the hub is recognized by the CX-919
- 2.4GHz Rii N7 Keyboard/mouse remote's dongle plugged into the hub is recognized by the CX-919
- Also using a 32GB microSD card inserted into the CX-919
- Using the Finless 1.5 ROM with 720 kernel
- USB on/off dongle works without issue
As mentioned in a previous thread, the Measy U2C-D dock does not come with a power charger so you will still need to purchase a charger. The barrel port fits a 3.5mm charger. There is also a microUSB power port, but I never used it so I can't verify it works flawlessly like the barrel port. IMO, the Measy dock is made of very light, cheap plastic material. During my brief time with it, the dock practically fell apart when inserting and removing the stick into its HDMI port.
This "alternative" dock setup uses parts that are all "fulfilled by Amazon" (except for the the USB on/off dongle) which allows for quick and free shipping along with Amazon's speedy return policy should you have any issues. With the use of the USB extension cable and on/off dongle you can still use your CX-919 charger, but now have the "luxury" of increasing your power cord's length by 10 feet with accessible on/off functionality.
Finally, aesthetically speaking, this setup works well with the CX-919 as everything is black in color (opposed to the Measy dock which is white and looked odd with the stick). Also, I attached the CX-919 to the top of the hub using black Velcro tape so that everything looks like one unit. I also attached the bottom of the hub to a shelf on my entertainment center using Velcro tape to ensure that it stayed put.
smithmal
