THL Super Box Amlogic Amlogic s912 2/16 AC WiFi, Fast lan BT4
    Main Features
    ● Amlogic S912 CPU, Quad-core, Cortex-A53 and 1.5GHz
    ● 2GB RAM + 16GB ROM for smooth running and data storage
    ● H.265 decoding technology saves half bandwidth
    ● Bluetooth 4.0 and dual-band WiFi for convenient wireless connection
    ● SATA for SSD and HDD extension
    ● Can be used as a mobile hard disk drive
    Gearbest
    Thanks to Gearbest today we get to have a close look at the THL Super Box Amlogic Amlogic s912 2/16 AC WiFi, Fast lan BT4
    Amlogic 912, 2/16 should do the Job and a HDD caddy to store your favs,
    Running Android 6
    Lets get looking at what we have.
    Box
    What's in the Box
    Look around not a lot to see:
    Power by USB cable/power supply usual 5v 2amp power pack, good idea.
    Nothing on the sides
    No Display just Led and IR pickup
    Handy Draw/caddy for your smalls or is it
    Remove base, interesting heat sink no Thermal Pad
    Looks like a some Jam and that aint my whiskers or the cat , must be a running repair.
    Remove PCB, you can see Sata Slot for Hdd
    Gearbest
    I recall seeing in the Gearbest thread buy one at a certain time of the day the first 20 are $49.00, might be worth a look.
      Great review, as always.
      Thanks trebor
        I like the challenge of setting my alarm clock, so I can get that device at the low, low price. However, after scratching my head for an hour, I can't think of ONE single thing I could use that device for...........
          Its can be a portable HDD for a start, plug into your PC and transfer files, like a Hdd Caddy, get them for under $10.00
          It can also act as a server with login with supplied server app I am yet to master, or get to work.
          Set up as a wifi hotspot so files can be transferred to others, yet to get it to login successful.
          It will only take a 7mm Newish HDD no room for any fatty 2.5 inch drives
          Android 6 dated but works, no big problems so far. PCB is dated 2018 so it's fairly newish
          2/16gb s912 some will have use, Not sure myself at this stage.
          The Special price is all its really worth I feel, More to come soon,
            More on this, file transfer, hotspot server thing.
            It works finally as intended I think, well stuff is happening.
            Under settings, more settings and more on the media player ensure that Portable Hotspot is enable,
            It's preconfigure with default PW etc.
            Install thl home app from the Playstore to your phone.
            On your phone under Wifi settings you should see the Box/Hotspot address.
            Connect to it with the default password. will connect.
            On the phone Run the app to set up the account name and default PW for now
            It will advise if successful or not.
            Once done login with app to box and browse, transfer files to or from
            This would be handy home for work need to transfer things to storage for use, but then we have keydrives and other ways
            Handy as a portable HDD caddy, then you can plug it in HDMI etc and browse to show and tell
            Portable transfer files Phone to caddy.
            Can see some uses that may be handy for some.
            Click image for larger version  Name:	Screenshot_2018-06-21-07-19-32.png Views:	3 Size:	128.0 KB ID:	732316Click image for larger version  Name:	Screenshot_2018-06-21-07-19-43.png Views:	1 Size:	447.5 KB ID:	732312Click image for larger version  Name:	Screenshot_2018-06-21-07-20-06.png Views:	1 Size:	410.1 KB ID:	732313
            Click image for larger version  Name:	Screenshot_2018-06-21-07-20-18.png Views:	2 Size:	93.9 KB ID:	732315 Click image for larger version  Name:	image_33491.png Views:	1 Size:	108.5 KB ID:	732311
            You can while the box is connected to Ethernet and doing internet stuff also connect to box via wifi direct/hotspot and do stuff, that may add some further use to some.
              To Continue with the THL Super Box Amlogic Amlogic s912 2/16 AC WiFi, Fast lan BT4
              Let's have a look at what is has going for it.
              As Mentioned running Android 6 doing the job ok.
              Google, setup all good, WiFi and Ethernet speeds also good.
              Updated and installed testers with ease.
              Has Roots access, NO upper or lower Bars
              Lets Do it
              UI and Installed apps: clean look like it.
              System Info
              Root
              Storage software HotSpot use: runs every startup
              DRM Info L3
              Ram and Storage Truth
              Aida64 Hw Info
              CPU-Z
              Temp looking Ok
              Geekbench 4 CPU
              Mores > http://browser.geekbench.com/v4/cpu/8742548
              Geekbench 4 Compute
              SD Card Test, not to bad at all.
              Bit of fun really setting it all up to use HDD phone etc.
              Just beware must be a skinny HDD 7mm or the draw will not go in, bit hack of plastic maybe required
              If you just slip hdd no caddy Beware the top of PCB is exposed so make sure its fully insulated.
              A6 2/16 good WiFi/Ethernet Puts along pretty good,
              The Bootanimation
              The current special at Gearbest is all its really worth, 20 a day for till the 22nd Gearbest thread
                How is the temp?
                  Surprised I thought that plate would need some packing or thermal pad but seems to be doing ok....
                  Yet to do anything way over the top, doing some video soon...
                  CPU_z shows high 50c..
                  And you just want to practice setting that clock...for early wake up,
                  Also this box has no rubber feet, its sitting heat side down on the surface direct so lifting a bit will help I feel also
                  Played for about an hour pretty solid use 70c using the TVCentre / Kodi on the box 17.1 i think a bit dated
                  so nothing too hot and if it was I am sure we can find a solution to fix
                    What is the model of the dedicated SATA III controller, as I can't see anything obvious on the board?
                    As Found
                    Firmware dated 07/10/2018
                    Source: CGR
