Is there a solution please?
T95Z Plus No wifi
Does it show other AP connections available? If so, when you do see your router, is it on top of all the others?
I have had that issue once or twice... vaguely remember the issues were with channels being too congested. Had to scan for the best channel to use with 2.4Ghz N. Found I also had to adjust the router to use upper or lower edge of the channel, where less overlap is. You want at least 30db of usable signal floor from the top of your channel.
How close is the router, and is there a direct line of sight, or is there obstacles, walls, or 2.5ghz, or 5GHz cordless phones near by. Your signal should for the most part be full bars when connecting the box.
also if you used a firmware not from your manufacturer, it could have driver issues.
There are currently 2577 users online. 1 members and 2576 guests.
